RCU Forums - View Single Post - HurriKane Kit
Old 05-08-2006 | 10:04 PM
daven
Default HurriKane Kit
I ordered a HurriKane kit from www.supertrc.com a couple weeks ago and started assembling yesterday. Dan Kane uses many of similar tab/slot construction techniques I used on my seeker and it looks like an easy build. He also has some great instructions set up on his website. I started with the fuse yesterday and after a couple hours everything was looking great.
I got a brain fart tonight and decided to mount an extra Neme-Q tail I had laying around gathering dust. Dan has a light ply fuse spacer under the V-tail that is set at zero degrees incidence. Terrences tail also has a flat bottom that is also set at Zero Degrees. With a couple minor fuse mods, I mounted the tail to the fuse and now will have a removeable bolt on tail.
Here are a couple pictures of the progress.
ID:	458420   Click image for larger version
