RCU Forums - View Single Post - Glow plug igniter. How does it work?
Old 05-09-2006 | 11:29 AM
donkey doctor
Default RE: Glow plug igniter. How does it work?
Hello; It should be do-able, you might run into problems if the switch that reduces the voltage for the glow plug is solid state. The switch should be before the voltage reducer. It evergises everything at once, and what you want to do is just energise the glow driver part. I would have to look at the circuit, but it should be do-able.
