RE: RCV Engines
I have an RCV 60 sp and I have just been flying with it 2night but I have a problem its starting to over heat a bit 2 much all of a sudden. When I mean over heat I mean over heat[X(].
After a 6 min run the engine is red hot, the carbs red hot, and the crank case is red hot, I have never had this befor?. The thing is in February I crashed this engine into the ground from 300ft+ broke the prop when I cleaned it up it seemed Ok no rattle or play in any part! of the engine.
But as I ran the engine it get's hot 2 hot I think well for the carb and the crank case to get hot so you can't touch it, thats hot.
do you think I've naked the bearings up in the cylinder/crank?[:@]
