I plan on getting a video of my Giles 202 on the maiden flight if I ever get a chance to work on it again. About the issue with the air flow in the cowl causing the engine not to run properly. Do you think if I took a sponge or piece of foam about 1/2" in dia. and 1/2" thick and glued it to the hole on the carb so it would act as a filter that it would work as far as stopping the turbulance around the carb??? I don't have a soldering iron so I'm looking for another alternative to soldering the tube on the plate.
ORIGINAL: jstanton
Zippi
Thier shipping charge is not to bad. I ordered 4 plugs and I think the shipping charge was onlt $4.00. The plugs cost $2.25 a piece if I remeber right.
Sorry to here your working to much. I know this has to be done, but we all need time to relax at the field. I want to see you giles in the air when you get her ready. Can you take some video of the maiden flight?
