RE: duratrax evader
The pin problem in the cv joints has a easy solution. Ask your local hobby shop for some heat shrink or cv rubber boots. They are both cheap.
You need to replace the stock shock oil. Use 30wt. It is cheap as well.
Everything I have recommended is less than $5 a piece.
