RE: Robart Hinges: opinions
I've found that at cold temps (freezing) these hinges can be weak at the pin when shear forces are applied. I had three 1/8" hinges fail simultaneously at the pin on the aileron of a 120" slope glider while flying in 35mph winds. The other aileron sheared off when I crash landed after the initial failure. Just be aware if you store your planes in an unheated garage.
