RCU Forums - View Single Post - Hacker A-60 for Pattern / F3A
Old 05-10-2006 | 02:25 PM
DaveL322's Avatar
DaveL322
Default RE: Hacker A-60 for Pattern / F3A
Jim,
The CC brake only engages when the throttle stick is at (or below) the set point (bottom click of throttle with idle trim centered, I adjust the low throttle ATV to accomplish this). I don't know for sure that the amount of brake applied is a function of RPM specifically, but it acts that way - this is particuarly noticeable on some motors as they "hum" (windings of the motor - feedback of sorts I guess) when the brake engages, and the humming gets quieter as the RPM drops, and is silent as the prop stops. I'll check with one of the engineers at CC and see if a more detailed explanation is available.
Regards,
Dave Lockhart
Team JR, Team Castle
[quote]ORIGINAL: OhD
If the CC actually brakes as a function of rpm and stick position it might be the best. Who is the expert at Castle? Maybe we can get a clear answer.
Jim O
[quote]ORIGINAL: Magne
