RCU Forums - View Single Post - Great Planes Cap 232 Build Thread!!
Old 05-10-2006 | 08:22 PM
Clayton Wheaton
Default RE: Great Planes Cap 232 Build Thread!!
I don’t like to hinge my surfaces until I mount my control horns, I like to set the surface up on a drill press and drill my holes straight and true. For glue I use the pacer hinge glue and love the way it works, but before that I put some Vaseline on the hinge right at the pivot point with a tooth pick. If you work slowly and carefully you should have no clean up on the wing or on your work bench. That’s my humble opinion!. thanks for the nice comments the plane goes togeather very easily and is very light this is defenitly a nice arf.
Clayton Wheaton
