Clarification required on Expander
Hello,
Need help confirming compatibility before placing order. I want to use sub-c dual 5 cell nicad system (need the weight for CG).
Option #1: Expander + SuperSwitchHD 2 pack.
Question: Are the connectors in the SuperSwitch different 'sex' so that both can go at the same time in the expander?
Option #2: Expander + BatShareUltra.
Questions:
a) Seems can't use SuperSwitchHD in the same setup with a BatShareUltra due to the connectors, right?
b) If can't use SuperSwitchHD then connect BatShre direct to battery? Seems using a 'normal' switch defeats the heavy wiring purpose.
I don't have a preference for either option, but need to make sure they connectors are compatible as I just want to plug and play!
This is going to a sport jet with 8 digital servos + 3/4 standard ones.
Edgar
