RCU Forums - View Single Post - Building an Engine Mount
Old 05-10-2006 | 09:55 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Building an Engine Mount
ORIGINAL: DavidAgar
Just punch out the old blind nuts, fill the holes with epoxy and install the new mount. You should be just fine. Good Luck, Dave
You could also use a dowel rod to fill the old holes. Insert a dowel rod to fit the hole and glue it in place, then saw it flush with the firewall when the glue is dry.
While it's possible to make a wood engine mount when the wood is part of the frame of the plane, you want to steer clear of that here. Unless it's constructed properly the chances are that it will fail. This could result in a dangerous situation if the motor is running as it could hit somebody and injure them. Install a regular engine mount.
Hope this helps
Ken
