RCU Forums - View Single Post - does changing oil mix change tune on DA-50?
Old 05-11-2006 | 06:22 AM
rc bugman
My Feedback: (30)
Default RE: does changing oil mix change tune on DA-50?
Hi,
Based on my extensive oil tests a year ago, you will have to richen the mixture when you change to Amsoil 100:1. The reason is that there is less oil to burn and provide power. Since oil has more power per gallon than gasoline, you have to open the needles to allow in more gas for proper combustion.
Hope this helps
Elson
