RCU Forums - View Single Post - CP2 binding issues
Old 05-11-2006 | 07:43 AM
OttoNP
Default RE: CP2 binding issues
You can balance the whole assembly in the helicopter, just loosen the coller on the main shaft and slide it down so the main gear disengages (or you can remove the motor). Then the whole assembly is balanced as one, this will give you the best performance.
