RCU Forums - View Single Post - First drift, spur gear stripped!!!
Old 05-11-2006 | 09:16 AM
CaptEvo
Default RE: First drift, spur gear stripped!!!
ORIGINAL: magnat
Stock 27Turn silver Can motor is Perfect for Drift..
There is no need to go psycho with a Brushless Set up..
Hell Most Pro Drifters use a Motor with no less then 19 Turns..
Most of them have found the Tamiya Sports Tuned to be the Ideal Drift motor..
They are Dirt Cheap , have ooodles of Torque which is what is needed for rc drift..
This is what we are trying to make RC'R's understand is , you Dont NEED a low Turn motor to drift.. Sure to Race but not to drift..
Are you referring to Team Orion Core Stock RS 27T Rebuild ?
http://www2.towerhobbies.com/cgi-bin...?&I=LXBSU8&P=7
Can someone explain the different between stock/Spec motors?
I heard 19T spec is good for drifing also.
