RCU Forums - View Single Post - SkyFly, T-hawk
Old 05-11-2006 | 07:09 PM
aeajr's Avatar
aeajr
Default RE: SkyFly, T-hawk
ORIGINAL: starpower4u
I have a T-Hawk that is VERY experienced w/crashing. In fact in about 20-30 attempts it has never had a successful flight. The problem is that it seems to have a very limited transmitter range at about 200' the signal is lost and it flys it's own way to the next crash. I've replaced the reciever to no avail. On the ground I can only get about 150-200' away before it stops reacting to my inputs. It seems to me to be very difficult to keep the plane this close to me and every time I've lost control. It certainly is a great testiment to how robust this plane is, many spectacular crashes that have left me amazed as I reach it intact. Transmitter has had fresh batts. in it a couple of times for no improvement.
I've been considering buying a "real" system, and hear that the Multiplex Easy Glider Elec. may be the way to go (closer to real anyway). Continuing to rebuild the T-Hawk and replacing parts w/o any improvement is not at all rewarding.
I'm surprised (and a bit encouraged) to hear that many on here like the T-Hawk, any advice as to what I should do?
My interest at this stage is to take advantage of the killer slopes and thermals on my property.
I always appreciate input!
-jeff
OK, T-Hawk radio sysetm, when working properly, should have a range of about 2000 feet, so you have something defective. Since you replaced the receiver I know you are working with customer support. Right?
If the receiver is OK, then it must be the radio.
Did you follow the range check procedure that I presume is in the manual? What range do they tell you it should be? Is the check doen with the antenna down?
1) Is the antenna tight?
2) Radio batteries fresh?
You have an electroncis problem.
