RCU Forums - View Single Post - honda gx31 throttle linkage
Thread
05-11-2006 | 09:52 PM
1
cheechukranch
Jan 2004
157
Livingston, MT
You guys that have converted GX31's: Did you modify the throttle configuration on the carb? I'm wondering if there is anything I can do to avoid using a high torque servo for this linkage. The existing lever requires quite a lot of force to open...and then is spring loaded on the return. Should I change anything or just set up a bellcrank linkage to a high torque servo? I'm new at this and would appreciate your voices of experience. Thanks!
Reply
Like
cheechukranch
View Public Profile
Send a private message to cheechukranch
Find More Posts by cheechukranch
View iTrader Profile
