RE: Static thrust of Da 50
At your elevation of 1500 ft ASL, and an approx. 6,800 rpm on the NX 23x8 = 30 lbs. thrust.
These numbers suggest that your plane should perform quite well as your power to weight is very close to a 2:1 ratio which is considered as fairly good for 3D flying.
Karol
