RE: G26 and kill switch
If you hook up a kill switch to a throttle rod you could accidentally kill the engine at the wrong time...Most gassers are set up to use the idle trim to completely close the throttle, killing the engine...The black wire on the source coil will kill the engine when grounded..I haven't seen the Great Planes kill switch, but it most likely takes a separate servo controlled by a switch on the transmitter....
