Ron
First take off the retract valve and put in a servo into the sequencer to confirm that the sequencer is functioning correctly, then test the retract valve. We have experienced a number of faulty valves as of late. Two that we received would not switch from one port to the other. Double check this by confirming that the light switches from one side to the other.
Dean W.
www.pstna.com
