RCU Forums - View Single Post - BRIO Electric 10-size
Old 05-12-2006 | 04:23 PM
  #77
BMiracleTX
Default RE: BRIO Electric 10-size
Glad to hear you are all having a good time with your Brios. I just maidened mine today...and buried it. I set it up exactly by the book...CG was spot on, expo, and control throws. I took it off and it only needed three clicks of up. Tracked really well but on low rates with 1/2 stick of elevator it would snap to the right [X(]
I kept flying. Knife edges, death slides, and high-alpha knife edges were SO easy with it!! I was flying the Park 480 with 2100 Thunder Power and the rudder servo up front. It needed slight down to fly inverted so I know it was not tail-heavy, but not enough down to be nose heavy.
I figured the incidence was off and I would check it when I got home.
For those who haven't tried it yet, the Brio does an awesome and slow inverted flat spin!! On my second inverted flat spin, I centered the sticks to recover, it nosed down, and I fed in some up to fly level and the SOB snapped right, nosed down, and BOOM...crushed fiberglass, wings and canopies flying everywhere!! Even crumpled and ruined my TP 2100 li-po.
Bottom line, anyone else have snapping issues with everything set up and balanced by the book? And before you ask, I straightened all of the crooked control surfaces so nothing was warped.
