RCU Forums - View Single Post - Robart Hinges: opinions
Old 05-12-2006 | 04:56 PM
SteveW's Avatar
SteveW
My Feedback: (36)
Default RE: Robart Hinges: opinions
ORIGINAL: amilder
I really wanted to use these on my Sig Mid-Star 40 but they are just too big (I bought the 1/8" ones) I measured the strip aileron material thickness and the length of hinge needed to keep two barbs (the minimum recommended length), and then calculated that the hinge hole would break out of the ailerons. I will still use them on the elevator (1/4" thick balsa) and maybe the rudder (3/16" thick- only leaves 1/32" on each side [X(])
The ailerons are standard 1" X 1/4" tapered aileron stock.
I'm not arguing with anything anyone is saying about the Robart hinges, they're great in the right application. Don't worry, your Mid-Star 40 will be just fine with CA hinges.
