RCU Forums - View Single Post - Midwest Extra 300xs Build
Old 05-12-2006 | 09:04 PM
  #261
Digger44's Avatar
Digger44
Default RE: Midwest Extra 300xs Build
Thanks, the ignition switch is going on the opposite side of the fuse from the receiver switches(2). The picture in one of the last post might not have made that to clear though. I originally placed it in the most forward engine bay but have decided to move it back one bay more into the fuse area above the wing where I can get to it after covering is applied. First pic shows the original location. The second pic shows the location of the two receiver switches mounted. Ignition battery will be mounted on the engine box left side and the ignition itself mounted on the right.
I received the servo arms from SWB and I will have to lift the aileron servo's up in the tray a little to have clearance between the nylock and the wing surface. Third pic shows what I mean, too close for comfort.
Pictures posting HUGE!!, will try again in a while.
