RCU Forums - View Single Post - spun a dogbone
Old 05-13-2006 | 05:11 AM
charlieboy
Default RE: spun a dogbone
ORIGINAL: jackkpl
79,4 to fit in 70mm place ? I don't think that 1cm difference is not gonna be crucial.
Thats less than 1 mm difference, you won't notice the difference, if you look at the shafts the ends are designed to allow for travel of the shaft when the suspension rides up and down. If the DB is less than 1mm shorter you won't notice any difference!
