RCU Forums - View Single Post - Blue Angel - Build
Old 05-13-2006 | 09:13 AM
  #231
8178's Avatar
8178
My Feedback: (17)
Default RE: Blue Angel - Build
I did some more trimming and fitting of the canopy. From its current rough cut state I taped it down in position with a short piece of masking tape on both sides. I then used masking tape along the lower edge of the canopy to mark the edge where I needed to trim. I put the masking tape on the canopy so that the top edge would be the trim line and of course I could see through the canopy to see the wood to know the trim location. The masking tape overlapped on to the fuselage. When I was done I cut the masking tape loose along the bottom edge of the canopy so I could remove it from the fuselage. Then I cut along the top edge of the remaining masking tape to trim the canopy.
To be continued…
ID:	460738   Click image for larger version
ID:	460739   Click image for larger version
