raideron...
First radio had a problem right from the factory. I had to send it in for service. This one is working good. I'm been setting up my Giant tonight. I got full spectrum ailerons, flaps, spoilerons, flaperons, air brakes, crow, elevators that act as ailerons. It's been very tedious to set it up. But, I'm taking notes and the next planes won't be nearly so time consuming.
It does make mixes much easier to understand and set up. It will be pretty cool when I start using it. My first attempt will be with the Giant. I should have that baby ready to fly on Wednesday or so. I'm completely done except mounting the engine and balance. I've even got all the trimming done on the radio now. This is a very pretty airplane. Just like it's little brothers. But this thing is HUGE. My intial weights with every thing should be right at 12lbs. The manual says 12.5. If this holds true this will be the first plane I've built that weighed less than expected. (refreshing) If the OS160FX is enough to fly at this elevation this will be a sweet flying airplane. I can't wait to try it.
Barry
