RCU Forums - View Single Post - Vertical flying or hovering ?
Old 12-19-2002 | 02:59 AM
midget racer
My Feedback: (7)
Default Vertical flying or hovering ?
well, there are several things to keep in mind when trying to " hover " or torque roll .1st most aircraft like an aft cg to hold well in a hover, so adjust carefully and slightly, 2nd you need alot of throws on rudder and elevator to keep from falling out,3rd you need to enter into a hover from a perfect vertical when trying to learn or else you will always fall out .4th use a large diameter high pitch prop, makes it much easier, if you are using an 11x6 on a 46 try going to a 12.25x 3.75 or a 12x4 .plus i am sure there are many more ideas people can think of , but above all it is nothing but practice practice practice.
