ORIGINAL: nchrome
Unless you plan on mixing the elevators with the ailerons
That's is exactly what I plan to do
. I refer to the control surfaces as stabilators, but in actuality they are ailerators (function both as ailerons and elevators). As to the weight factor, I'm hoping the hardware from the other mods in the forward section of the aircraft (speed brake, L.E. Flaps) will help balance out the tail without adding a ton of weight in the nose. I do know that I'll have to move the radio equipment as far forward as possible for CG.
ORIGINAL: Haveblue
MRM..I like your work!
Thanks for the kind words
Mods
