RE: Firebird Freedom
I sent you a PM,
By the way, what are you for a charger? I think that the original charger may only be good for 4-7 cell Nimh and it also does false peaks and you need to unplug and the replug them back in the cigarette lighter.
Did you upgrade the battery already? if so since you are using more cells, how are you charging this battery? Do you have a different charger than what the plane comes with?
That may be your problem. you can not charge the 8 cell Nimh using the original charger supplied with the plane.
I hope that helps, read the sticker label on the charger and/or owner's manual to verify.
Good luck and I hope this helps.
Gryphon
