RE: Nitro Models Cessna 337 - Build Thread
I have cut out the windows for the cabin and glued them in place using a flexible, clear plastic canopy glue that I bought at the local hobby shop, Eugene Toy & Hobby. I cut out the canopy but will wait to do the final fit on it until I have mounted the wing in place.
The engines are both installed. I'm debating whether I want them both on the same channel or if I want to use the channel 6 knob for the rear engine throttle control. The only issue I'm seeing with that is the throttle cut-off option.
I'm using so many Y-harnesses in this rig so far it's ridiculous!! I have installed 7 of the 11 servos, (9 standard, 2 micro) I will be using. I have a 6 volt, 2100 mah battery that I will be using for the receiver. I plan to charge it between flights. Anyone believe it won't be enough for all those servos?
