RCU Forums - View Single Post - NORVEL .049 HELP
Old 05-14-2006 | 06:15 PM
walleye5
Default RE: NORVEL .049 HELP
Andrew,
Thanks alot for detailed response. I follow you on the porting, the prop info is very helpful as well. I will keep you posted, when I get off the ground. So many hobbies, and you know how it is when you are trying to get your feet wet in one, (again), you simply must pick brains and combine all data to come out a bit further ahead than attempting to go it alone.
Much appreciated.
Regards,
Bob
