RCU Forums - View Single Post - Mid Star 40 Build Thread
Old 05-14-2006 | 09:30 PM
  #32
dbruening80
Default RE: Mid Star 40 Build Thread
Lets start with the motor mount, it is a simple process of locating the center and thrust lines from the plans and laying those lines out on the firewall. Next, we determine the spacing of our mounting lugs on the engine, transfer those measurements to the firewall and mark and drill the mounting holes for the mounts. We then drill holes for the blind 6/32 blind nuts and install those on the rear of the firewall, I secured them with slow ca, then we bolt up the mounts and check out fit. You can see in the 2nd pic the hole for the throttle cable
ID:	461549   Click image for larger version
ID:	461550   Click image for larger version
