Originally posted by easymoney
Its normal but I think the radio manufacturers should consider this issue as this can strip the gears if the servo is already at its extreme end, mostly in throttle.
I have seen all brand radios but JR has some control over this.
I don't agree to first turn the TX on and off last. First turn on the RX to see whether your Channel is free or not... just be on the safe side
It shouldn't strip the gears, as the servos are not trying to hold that position. Its momentary, and shouldn't hurt anything.
I do agree with you to turn on the RC first, then the TX after you see that your channel is free. I've been in that habit for years now. Never stripped any gears, but did have more than one instance where the control surfaces were obviously being controlled by someone else. Both times, there was a person on the frequency that didn't have the pin! Luckily for them I have this habit, as it saved them a plane and me the possible argument proving I had the frequency.
