RE: brushless blast time again
I would go with the 4.5 turn motor. I have heard a lot of good things about it.
Also with this size case torque should not be a problem nor would I sacrafice RPM's for torque. (with the same motor) A smaller, faster turning prop will yield greater speeds compared with a larger, slower turning prop. Although the motor with greater torque/less RPM will produce more thrust to move more weight.
Ryan
