RE: YS 63S Won't Hold Idle
No problem with the tank height. The regulator is leaking. Try turning it in 1/4 to 1/2 turn to see if the carb leak stops. If it doesn't, the reg could have a piece of debris holding the plunger off the seat. Take the reg apart and clean it if turning the screw clockwise doesn't help.
