RCU Forums - View Single Post - Saito Velocity Stack Test
Old 05-15-2006 | 02:33 PM
TimC's Avatar
TimC
Default RE: Saito Velocity Stack Test
Ernie, I was using a fine mesh filter. I'm thinking it would have less effect on a smaller engine using the same sized stack and filter. I really need to repeat this test a few times to make sure the time is correct. I live in town and try to hold test running to a minimum. I'll be doing my .56 next and will run the same test with it. Let me pull the filter off and tach the peak.
