RE: Shocks
I just measured the shocks on the Tornado. They're 3 3/8" from end to end. The bottom is mounted with a m3 set screw thru a arm & top is a ball mount on the shock held to shock plate with M3 phillips screw. Volcano's use the same setup but the shocks are almost 4"
