RE: YS 63 PROP SLIP
Club20racer,
I have 3 YS63 and two of them did what like you said. I don't know what I'm doing wrong but as a solution I just use the sandpaper disc trick. I also file small grooves behind the prop hubs. This solution is not permanent, once in a while it'll need to be redo but usually I broke my prop long before.
