ORIGINAL: newbladepilot
Hey Zoo,
I think I read somewhere that the leading edge of the tail rotor should rotate up into (toward) the main rotor. Think it matters?
If it does this new TR may not work.
The pitch is the opposite of the stock which means the only way the new rotor would move the tail to the left would be to have it turn CW instead of the stock CCW.
If the leading edge up into the main rotor doesn't matter then I don't have to switch anything, just bolt it on.
It still has to rotate the same way. If you keep the motor shaft on the same side, you mount the blade backwards and reverse polarity. I'll have to fire mine up in the morning and see which way it actually turns. Never really paid attention to it. Maybe since I'm on the opposite side, that's why it works on mine.
