RE: Need help with Volcano shocks
If they're plastic shocks stock, I'd definitely have a look-see and make sure there are no cracks in the body.
if there's no crack, then it should just be down to the O-rings that seal the shock where the shock shaft goes into the shock body. $.50 fix if that's the case.
I personally would recommend upgrading to aluminum shocks, though.
