RE: Tail rotor, How does it work?
Thanks. Just to make sure were on the same page, what is t/r, trim, and subtrim? Will I know when I have the hover offset right when I can take the heli off the ground and it does not yaw at center stick? If it does yaw do I adjust the trim? If its way off do I take off the linkage from the servo and adjust that accordingly. I was thinking the trim was those tabs that slide side to side or up and down. They make a clicking noise when you slide them. On my transmitter the right stick always goes to center. It feel like its spring loaded to return to center when I release. The throttle is the only one that stays where I put it. Also how to you go about adjusting your gyro?
Greg.
