RE: Homemade rudder w/pics
Boy, that takes me back. I used to make my own struts and rudders using the same method but used steel for the blade instead of brass. The only difference is, I found that splitting the rudder post weakened it so it failed easily if it hit something. I changed to slotting the rudder blade and low temp brazing the post into the slot in the blade. Nothing fancy and they work fine.
