RCU Forums - View Single Post - GP CAP232 Build
Old 05-16-2006 | 12:20 PM
  #117
insalacosm's Avatar
insalacosm
Default RE: GP CAP232 Build
Thanks for the tips guys. I played around with the stock 60 degree header and found that I can keep the muffler inside the cowl with about 1/8" clearance to the fuse and the cowl. It gets tight with the muffler extension so I'll probably open up the bottom of the cowl a little so the extension fits better. If I could bend the 60 degree header to 80 degrees or so it would be a much better fit. Do you think this is possible if I were to heat the header using a blow torch?
Also, I remember that some are mounting the tank higher than the recommended position so it is in line with the carb. Is anyone successfully running their engine (without a pump) from the location recommended by GP?
thanks again,
Steve
