RCU Forums - View Single Post - Nemesis Idling Issue
Old 05-16-2006 | 02:12 PM
abonnet
Default RE: Nemesis Idling Issue
Jombo,
the gap you talk about... are you refering to a gap between the LSN screw and the screw housing? or the gap in the venturi that is created by the barrell opening?
So now all works great for you? no shutting down even if you give it full gas, then full stop, then full gas, then full stop, and so on as you would on a track? if so, you are a genius.
