RCU Forums - View Single Post - Saito Velocity Stack Test
Old 05-16-2006 | 06:30 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Saito Velocity Stack Test
The Saito 100 and 125 Golden Knights do not come with a velocity stack.
I have a couple 100's and the inside of the velocity stack which bolts right on, is almost the same size as the throttle hole in the barrel. They seem to run "OK".
I do not have a 125 but the screw spacing for the carb is the same because the 125 uses the 100 back plate.
