ORIGINAL: sargeantspitfire
hey i hav a question. I have a blade and i crashed it a couple of times hehehe but when I put the new blades on i plugged the batttery in and I highered (which isnt a word but) the throttle and the blades started to spin untill I got to almost take off it starts to idle and stayed the same speed. the light also was green untill I get to 3/4 throttle on the transmitter then it goes red and makes a wierd noise. I tried charging the battery many times but no luck any ideas?
Check your tracking. Sounds like the blades are fighting. You could also have some slight negative pitch.
Dennis---you're correct, but if you look from the back you realize the tail rotor itself is actually turnig CCW. But as Lynxman pointed out, it don't matter as long as it flies.
