RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 05-17-2006 | 10:08 AM
  #3222
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: Dennis Flora
Who sells the pinion gear pullers ? and do they also have something to push it on ? Also, who has this DD Motor and push on Tail Rotor. I sick of defective TM's...
I got mine at the hobby shop in Jacksonville. My local shop doesn't have them. According to bladecprepair the part # for the motor is GW/EDP-50H. The prop is a 3" push-on prop with for 1.5 mm shaft.
You can see what the pinion puller looks like here http://www.lynxmotion.com/Product.as...&CategoryID=71 Most shops carry this because you use the same one for cars and planes. The hard part is finding someone who has separate pinions. The more expensive choppers usually come with different size pinions as part of the kit, so larger pinions are more common.
As far as pushing them back on, I use a rubber mallet or pair of pliers.
