RE: Blue Angel - Build
I completed more work on the wing by gluing the ¼” balsa strips on the back edge of the wing. To make sure the wing edge is straight I put the wing back into one side of the foam block that it was cutout of and position it so the trailing edge was hanging over the edge of the block. I put some light weights on the wing core and sighted down the trailing edge to make sure it was straight. I then glued the ¼” balsa on and tape it with masking tape.
To be continued…
