RE: Carburetor Problems
yep, use an old exhaust spring to help pull carb back to its close point (1mm open or what ever the setting may be). Also, check out how the rustler linkage is set up, Im running that set up on my rush, it has the spring on the rod between the servo and linkage, set the tention so it helps push cab back to closed setting. Under 10 dollar fix.
