RE: Goldberg Ultimate 10-300 build
Glad to hear you were able to locate some ailerons, tuwood. Thanks 4 the pictures & info . of the bottom wing mount. I'll try and reinforce the same area. I'll probably have a few "hot" landings the first couple of times, till I'm use to the aircraft, so I'm trying to avoid any breakage the first few flights. Thanks Again,
Dave
PS I was refurbishing my old 4*40, and I'm taking off some old covering. Seems like it took my 1 hour just to do 6 square inches. Does anyone know of an easy way to remove covering? I tried heating it up, but it seemed to make matters worse. I either got it to hot when covering and melted it to the wood or some CA soaked through the balsa sheeting.
