RE: Kangaroo wing bolts.... HELP !
note: my picture shows only one spacer on the wing bolt, you will need two. If you use just one the bolt can back up inside the fuse.
The fender washer is to distribute the load the of the wing bolt.
Otherwise the 6 mm socket head screw will crush into the plywood when tightened.
Canard-A-Roo Bob
