Servos for my TF Giant Corsair
Thanks Dave, thinking the same thing myself, I re-fitted some new hatch covers to the wing that would better accomodate the larger servos as I would feel way more secure with the power of these big boys in there. There is a servo tray mounted in the fuse that will require some refitting as well and a couple of notches in the flap servo mounting rails should allow me to fit a couple of airtronics 161's in there (100+ ozs). Seems like I'll be able to get it to work all right, but wow, guess, Top Flite wants you to use the expensive high power standard size jobs that drop right in. One problem is that the pushrod sleeves are all ready glued into the prefitted guide behind the tray and I hope that the slightly higher posts on the larger servos will work all right without having to rip this out as well. I might still get some Hitec 605's to drop in there if they would be strong enough.
